quietpeen
Administrator
Staff member
Front:
Front Active Damping Sensor Bolt 89 inch lbs. (7.4 ft. lbs.)
Hub And Bearing Bolts 41 ft. lbs.
Lower Ball Joint to Knuckle Nut 27 ft. lbs plus 180 Degree Turn - X
Lower Control Arm to Cradle Bolt and Nut 136 ft. lbs
Rear Active Damping Sensor Bolt 89 Inch lbs (7.4 ft. lbs)
Shock Absorber Shaft Nut 74 ft. lbs.
Stabilizer Bar to Cross member Bolts 48 ft. lbs.
Stabilizer Bar heat Shield to Crossmember bolts 44 inch lbs. (3.7 ft. lbs)
Stabilizer Link to Stabilizer Bar Nut 100 ft. lbs
Stabilizer Link to Strut Nut 111 ft. lbs.
Strut Clevis to Lower Control Arm Bold 125 ft. lbs.
Strut Clevis to Strut Pinch Bolt 45 ft. lbs.
Strut Mount to Body Nut 20 ft. lbs.
Strut to lower Control Arm bolt 128 ft. lbs.
Tension Strut to Cradle bolt and Nut 136 ft. lbs.
Tension Strut to Knuckle Bolt and Nut 50 ft. lbs. plus 90 degree turn - X
Upper Ball Joint to Knuckle Nut 35 ft. lbs plus 90 degree turn
Upper Control Arm to Body bolt and Nut 66 ft. lbs.
(X) New Fastener Required. If removed do not reuse. A new Fastener must be used.
Rear:
Camber Link to Crossmember bolt 72 ft. lbs.
Camber Link to Knuckle Bolt 72 ft. lbs.
Compression Link to Crossmember Bolt 72 ft. lbs.
Compression Link to Knuckle Bolt 72 ft. lbs.
Hub and Bearing Bolts 44 ft. lbs.
Hub Nut 170 ft. lbs.
Shock Absorber Upper Bolts 46 ft. lbs
Shock Absorber Lower Bolt 96 ft. lbs.
Shock Rod to Shock Mount Nut 18 ft. lbs.
Spring Link to Crossmember Bolt 81 ft. lbs
Spring link to Knuckle Bolt 105 ft. lbs
Stabilizer Bar Bushing Bolts 45 ft. lbs.
Stabilizer Link to Knuckle Bolt 45 ft. lbs.
Stabilizer Link to Stabilizer Bar Bolt 45 ft. lbs.
Tension Link to Crossmember Bolt 72 ft. lbs.
Tension Link to Knuckle Bolt 72 ft. lbs
Toe Link to Crossmember Nut 66 ft. lbs.
Tow Link to Knuckle Bolt 70 ft. lbs.
Wheel Speed Sensor Bolt 97 inch lbs. (8.1 ft. lbs)
