2017 charger projector light options
Discussion in 'Lighting' started by quietpeen, Sep 29, 2017.
    that is true.
    where did you mount your ballasts when you did the install?
  3. 0212353
    Ours......had the ballast mounts on the side of the lights.
    Truly though, anywhere you can double stick tape a ballast on, all set.
    ok cool
    this
    Is that the stock or aftermarket ballast?
    stock!
    so you and Matt are using stock ballasts with aftermarket projectors and bulbs?
  9. 0212353
    Matt's lights utilize an aftermarket projector with stock bulbs and ballasts. We where able to source a pretty nice D3S projector for his.
    Mine, stock HIDs. I didn't swap the projectors this time around.
    ahh ok....that's pretty nice though not having to deal with wiring and mounting the ballasts
