You actually can pull a fuse and keep the valves open - worked on my '17 Scat.
What you do is pull fuse #36 (Electronic Exhaust Valve Fuse) within 15 seconds of starting the engine.
This will leave the vales open - HOWEVER it will also turn on the Check Engine Light.
An easy and cheap way to see if you like the sound.
Biggest complaint with the valves constantly open is the drone when 4cyl mode kicks in, which you can eliminate by staying in sport mode all the time.
ETA: I am old and a cheap-ass, I decided I preferred the active exhaust as is..
