SMOAK
Full Access Member
HAS ANYBODY INSTALLED A ...JET POWER CONTROL MODULE ON THERE CAR?? RESULTS IF YOU HAVE..
Fyi. I order the Tazer and i installed a 87mm throttle body from Modern Muscle Extreme.. have oil and transmision magnets coming.
Did you notice a difference with the throttle body?
I don’t think I have ever heard any good about the jet power control module
There is better throttle responce but power gains i dont know. Still early into the install. Its something i do just because. Lol. I would think someone wouldve tried the Jet product. Maybe someone will reply soon
I ALSO INSTALLED A OIL CATCH CAN ON MINE. THAT REALLY WORKS. SHOULD BE ON EVERY VECHICLE OUT THERE.
I will probably put a catch can on one day. I just don’t want to spend the money then wait the couple months it takes for billet technologies to make a customized one
I have a catch on on my '12 RAM 1500, because the PCV hose runs right into the intake.
not sure I see a reason on the Charger since the PVC goes in after.
They all go in right in behind the throttle body somewhere. To reburn the bad crap.
On the Rams with the 5.7 for some reason it actually goes back in before the throttle body
