LED vs HID?
Discussion in 'Lighting' started by F8Vendetta, Jul 2, 2019.
  1. F8Vendetta
    F8Vendetta Full Access Member
    So I hate that my fog lights are a nice white color, but my Hi/Lol bulbs are a boring warm temperature bulb. I want to make them white as well and wasn't sure if I should do the plug in and play LED or do the HID's which are apparently cheaper but seem like slightly more work....
    https://www.diodedynamics.com/hi-lo-beam-led-headlight-for-2016-2019-dodge-charger.html
    https://www.diodedynamics.com/hi-lo-beam-hid-conversion-kit-for-2016-2019-dodge-charger.html
    Curious because it's all 20 percent off for this week and figured I should take advantage
    Hid’s will absolutely give you better light output and most likely will be cheaper. If you want led though make sure they are ones designed for projectors.(diode Dynamics makes some but I’m not sure if it’s the ones you have listed)
    F8Vendetta likes this.
    SL1 Leds are pretty close to the top of the game right now and by the videos supposed to be a good beam pattern.
    Hids are usually a save and good option for any car. Both good for projectors for a better focused beam pattern.
    LEDs have been slowly getting better (more expensive brands) for good beam pattern.
    SOme of my local charger friends have been getting Aux beam LEDs but I'd go with Diode for higher quality and better customer service.
    You might have to put a hole in the dust cover for the wiring for the leds and will definitely have to for HIDs. Make sure whatever holes you make seal them back up 100% and make sure the dust cap is fully locked on otherwise you will get moisture inside.
  4. F8Vendetta
    Hmmmm decisions decisions lmao
  5. F8Vendetta
    If I do HID will I need to purchase the antflicker module?
    id talk to Retroshop for HID part. He can get you the right stuff
    This. Get in touch with Jeremy from retro shop. His website is retroshop.us and most likely yes
    You will need antiflicker
    Modules with HID or LED
  8. F8Vendetta
    Awesome thanks guys I'll hit him up
    I messaged Jeremy about this thread. Hopefully he will chime in
  10. F8Vendetta
    That would be even more amazing
