New headlights for the goblin
Discussion in 'Lighting' started by LB3711, Oct 5, 2017.
    As its known now. I got Retroshop headlights. Maxed out options. So happy and love them. What a bitch to get the bumper off for the first time.
    Mod list:
    Painted housings
    Etched Lenses
    Upgraded Clear HID projector Lens
    Diode Dynamics RGBW Demon Eyes
    Diode Dynamics RGBW C Lights
    Prototype Diode Dynamics Switchback C Lights.
    Now pictures.
    Some lamo lit pictures. Ill get better lit pics better.
    Very nice. Any progress pictures?
    yes there are pictures of a lot of stuff. I will eventually post in here and label them
  5. 0212353
    those look vaguely familiar......... ;)
    lol
    some install pictures
    Unplug the plug from the back of the fog light
    There is 3 bolts on each side of the fender to bumper.
    2 up inside the fender that has to be reached from inside the wheel well.
    Removing the wheels makes the job 100% easier
    Need to remove at least half of the inner wheel well liner to make the job easier to get up on there to get to said 2 bolts. 10mm bolts
    Unplug the side marker light plugs
    the top bolt is easy to get to from under the hood also 10mm
    Inner fender plastic pins. On my car with the cooling ducts there is 3 that are different. I only removed the front half or the liner. But the liner is rivited in the center so it wont come out of the car unless you completely remover the entire liner.
    Just remove just the bottom bolts to the bottom of the bumper not the plastic clips. I think 7mm
    Frontal view of the bumper removed
    Need to remove all the plastic pins in the black plastic part under the hood
    Did notice that on the drivers side brake duct that there is a scoop that directs some of the air right up into the air box. On Mopar box its open on top, in front and bottom. in that area its all open so all the air that get scooped up goes right to the air box.
