P0513 Incorrect Immobilizer Key ('Immobilizer pending SAE J1930 approval)
Athan Alexander
New Member
California
I might possibly have a bad alternator, but that's another issue. I got an OBDII scanner/reader tool and while my check engine light comes on, the only code it reads is "Incorrect Immobilizer Key". I have read that this can happen if the battery is unplugged for too long (which mine was, as it was dead and then I left it charging at AutoZone.
I am using the original fob key - is it safe to use the tool to clear the code with the original key in the ignition, or will this lock me out of the PCM?
first welcome to ChargerForum. I wish i could answer you question but i can't
sorry nobody here could help, but did you ever find your answer?
