Hello All, I was invited by Korney to check out this Forum so here I am. I own a 2007 SuperBee SRT8 6.1 Hemi. Retired 4 years now after working 40 plus years for Chrysler Canada. My Bee is my Baby and only I am allowed to work on it. Bees rules not mind.
I am all about improving the quality, longevity, and performance of our cars with better products that will reduce unnecessary repairs and save us all $$$$. There is a quality issue that affects all Dodge Owners that needs to be addressed but no one talks about. Rust from condensation caused by heating and cooling of the engine.
For those that do there own oil changes etc. you should have noticed that the top yellow plastic dipstick handle around the "O" ring has rust on it. That rust is also present inside the tranny dipstick tube as well as the Coolant transfer tubes that run from the water pump under the heads to the firewall and supply inside cabin heat during colder weather. Your plastic Coolant pressure tanks are discoloured not only from Glycol but RUST as well. These tubes are made from low quality carbon steel.
I am currently trying to source a shop that will make me these tubes out of 304 stainless steel. They will be replicated from the OEM parts. In addition to these 4 tubes I want to fabricate upper and lower Rad Hose tubes for my Bee.
SO the reason for this post is to see if there is any interest from owners that would like to improve their cars with better parts as well as add some bling to their engine bays. The larger the order the cheaper the parts will be.
Oil Dipstick tube -
Transmission Dipstick tube -
Coolant transfer tubes outlet and return -
Upper Rad Tube -
Lower Rad tube -
All Tubes will be made from 304 stainless steel, NEVER RUST, can be highly polished. These tubes will fit all 5.7 and 6.1 engines. and are probably the same parts on the 6.2 / 6.4 engines but needs to be confirmed.
Please reply to thread if you are interested in any of these tubes.
Oil Dipstick tube -
Upper Rad Tube -
Lower Rad tube -
