Tazer installed
Discussion in 'Engine & Performance' started by LB3711, Aug 31, 2017.
    you hope lol
  2. Shaggy
    Arizona
    Ha ha, true!
    after 3 years i wont care. I can reuse it again or sell it
    i was saying that you hope the car goes back to stock lol. Although I doubt they will check that the sport button functions properly on a lease turn in.
  5. 0212353
    If its a setting that you change and pull the tazer.......you will have to change that back to "stock" if you care to.
    If its a setting that is only active when the tazer is installed.....well.....no brainer.
    IE - DRL drop with turns. You set it, leave it on and done. It won't revert back unless you change it back before the car is gone.
    will that prevent it from turning the DRL when you use your blinker? I didn't realize it turned it off from factory and saw my car in the reflection on the car in front of me and thought my DRL stopped working
    I didn't change that. I do have the fogs on with the highs. I noticed do I g that I lost the automatic high beam function.
    I have automatic high beam on the ram and don't use it because with the hid's' the reflection off signs and other things is so bright it thinks there is a car coming in the opposite direction and turns off the highs. And in certain areas it's on of on off on off
  9. 0212353
    Yup!
    You will want to turn this feature on when the new headlights arrive.
    I assume in stock form it turns the drl's off to help make the blinker more noticeable?
